EGR Mod?? what does it do?
Old Feb 21, 2003 | 01:22 PM
Manny00z28's Avatar
Question EGR Mod?? what does it do?
Can anyone explain what the EGR mod on ls1.com actually does for your car? any imput would greatly appriciated. Thanks
Old Feb 21, 2003 | 01:27 PM
My84Z's Avatar
i would like to know this also? thanx
Old Feb 21, 2003 | 01:45 PM
GrdLockV6's Avatar
The EGR pipe protrudes down behind the throttle body, and slightly restricts airflow. Basically in the mod you get rid of the restriction, which is so small, I doubt you'll see .5hp off it. Not worth the time IMO.
Old Feb 21, 2003 | 01:50 PM
MARSTAUT's Avatar
If that on a stock engine, It something you would do if you have heads and cam, when more intake air is more important.
Old Feb 22, 2003 | 01:12 AM
stik6shift98's Avatar
was gonna do it but decided against it...
Old Feb 22, 2003 | 09:28 AM
steve10's Avatar
Benifits include:
1) Repairs stumbling problems at idle from defective EGR.
2) Keeps engine and intake MUCH cleaner since your not recyling burnt exhaust gases.
3) Cleans up engine bay clutter.
4) Makes header changes/intallations easier since there are less components to re-attach/remove.
5) Less components to troublehoot if your having problems.
It's not a HP mod. If you need more help email me or call me, I can set you up with what you need.
Steve
Old Feb 24, 2003 | 11:50 AM
Manny00z28's Avatar
thanks for the help.
Old Feb 24, 2003 | 01:31 PM
stik6shift93's Avatar
Originally posted by steve10
Benifits include:
Steve
I believe he was actually speaking of the mod where you cut off the piece that protrudes into the intake not competely deleting it. But good point, if you're even gonna bother shaving it just take it off altogether, you just need block off plate and need to have someone delete the egr code from the pcm.
Old Feb 24, 2003 | 02:56 PM
ratio411's Avatar
I wasn't going to do it until I had the hose off the TB and looked down in there...
If you open the blade and look, it actually appears to be a significant blockage. Image trying to run hard with something comparable restricting your windpipe.
One look made my decision to do the mod. It probably didn't do a whole lot, but it couldn't have hurt!
Good luck
Dave
marlar98
Oct 21, 2015 02:02 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
Pwilson59
Sep 3, 2015 08:47 PM
CARiD
Jul 7, 2015 08:19 AM
