EGR delete.......
I have a 99 LS1 and I want to get the LS6 intake w/o the EGR from gmpp and the get the EGR delete kit from LS1speed.com.......can this be done???Or should I get the LS6 intake w/EGR??
94 Z28 m6
cold air,air foil,b&m ripper,vortech tb elbow,underdrive pulley ,flowbasterd muffler,moded maf,poly trans mount,fuel pres reg,exhaust cut out........new mods 355/with 12# of procharger boost
99 Camaro SS m6
#133
MTI air lid,some free mods,B&M Ripper,MacEwen Motorsports WFG with no high beam thingy....slp longtubes w/o cats,zo6 maf,z06 clutch,jet pcm,qt cut out
Big Red(truck)
406 ci,700r4 w/3000 rpm stall,3.73 10 bolt.
No more 406..kaboom / on the way 427 mighty mouse
94 Z28 m6
99 Camaro SS m6
#133
Big Red(truck)
So nobody has anything to say about this???.........hhhhmmmmmmmmmmm.....Really!!!!!!!
94 Z28 m6
99 Camaro SS m6
#133
Big Red(truck)
94 Z28 m6
99 Camaro SS m6
#133
Big Red(truck)
I deleted the egr on my LT1. there's no reason to not do it. all it does is increase intake air temp. by adding exh. gas's to lower emisions. plus, on the LS1's, it will add alot of needed room to working on changing sp. plugs on the pass. side. but you will have to have it deleted from your program. chris
sleeperZ96BT
Sep 9, 2015 08:28 AM
