Egr?
Egr?
I am having a weird pinging issue with my 99 SS i will be cruising at about 30 to 40 mph and just give slight gas and it starts to ping.could it be a bad egr?Or should i start by giving the car car a full tune up!Thanks
You could, but why? Removal is just as easy, and it will prevent the pooling of the chemicals in the bellows. And with the intact tract removed, you can inspect the throttle body bore for carbon deposits and clean if necessary. Peek inside the intake manifold (through the throttle body) to inspect for excessive oil, and if present, could be the reason why the Seafoam treatment is necessary...
sleeperZ96BT
Sep 9, 2015 08:28 AM
