E-brake felt like it broke
Tonight I parked my car and when i went to pull up the Parking/Emergency brake, it went completely vertical without any resistance. I let it back down and when I pulled it up again the second time, it was fine. Did this ever happen to anyone??
I've never chased down the problem but have had this happen many times on many, many different f-bods. It just seems to be "one of those things".
Tom
T BYRNE MOTORSPORTS - www.tbyrnemotorsports.com
LT1 and LS1 Sales and Service
Hours 9AM-5PM EST Monday-Friday.
Order line - 1-877-4-TBYRNE
2002 Supercharged 8.1 Suburban - Project underway now!
2001 Supercharged 6.0 Suburban-15.87 @ 88.41
2000 Millennium Yellow C5 convertible- 11.92 @ 115.01
1998 Vortech powered Z-28- 10.89 @ 130.03 with 346 motor and Vortech - new ETs with 409 motor and ATI F1 supercharger coming soon!
E-mail tbyrne@tbyrne.com for lowest pricing for Vortech and ATI superchargers!
Tom
Same thing happened to me immediately after my rear end swap. Thought the shop forgot to hook it up. Tried it again and it's been working fine ever since.
A4 (3.42)/Whisper Lid/Corsa Catback/FTRA/BMR STB, LCA's, APHR/160+Tstat/SLP Fan Switch/HPP3
My '95 did it also,I "think" it's the little weight thingy that helps apply the brakes when the cable is pulled.I know that after I swapped my V6 rear drums for discs it started doing it.I lubed the little weight thingies and it stopped for a while.Maybe it gets hung or something and puts slack in the cable?
By the way,I hope no one got confused by my technical jargon
Kevin
1998 Black Z28
SLP lid,SLP MAF ends,!FRA,!EGR,and a Dynomax cat-back
1/8
8.54 @ 83.64 mph
Pics
Kevin
1998 Black Z28
1/8
8.54 @ 83.64 mph
Pics
yep, same bs happens to me too sometimes. I hate it cause when I have a passsanger on the car it looks cheap and it can be embarrasing. GM puts great motors in these cars but skimped on MANY "little" quality things. I have driven the snot out of my 98 and have never had any mechanical problems,but I have had numerous little things break such as the ash tray cover, the e-brake handle you mentioned, speaker went out, broken seat belt straps, etc etc.....
Rick
Rick
It happens to me every once in awhile too. It's probably happened about 10 times in the 4 years I've had the car.
* 1998 Trans Am A4
* 292 RWHP / 309 Torque
* before cam and FLPs
* 330 RWHP / 334 Torque
* mods: G2 sway bars, KB DD subframes, Tbyrne LCAs - panhard rod - & ported MAF ends, TR 224/224 112LSA 561 cam, FLPs, whisper c/f lid, K&N, HAL/QA shocks, NGK TR55 plugs, FTRA, custom tuning and a few other things.
* 1998 Trans Am A4
I know in the 3rd Gen Camaros it did that by design. It was made to release so that you could get the consol off or do maintenance on the E-Brake system. I don't remember what is was that made it do that, but it even said in the manual and the service manuals that is was by design on that car. Maybe it's carried over into the 4th gen too?
I wouldn't worry about it. it has happened to me as well, but its so you dont break the cable is all. it only happenss when you put the parking brake on when your still heavy on the brake pedal.
Scott Parkinson
2001 Sunset Orange Z-28
SLP Loud Mouth, K&N, Mass Air, 160 Thermistat, Power Programmer, All aftermarket suspension/braces, 8.5mm Plug Wires, 125 hp Shot. Runnin low 12's all day.
Scott Parkinson
autoxr166
Sep 25, 2015 04:21 PM
