dumb cutout question...
Are you guys saying a cutout isn't worth it if you have a Cat-Back System? I have a Corsa Cat-Back, and I am getting FLP Long Tube Headers soon. Will a cutout not help me out any? Be a waste of money? Thanks.
------------------ --Michael '01 Camaro SS A4 Mods Include: Superior 3.73 Gears, Jet Chip Racing Chip, K&N Air Filter, Free Ram Air Cut-out, Granatelli MAF, Whisper Induction Lid, Corsa Cat-back Exhaust, Jet PCM Controller--Calibrates for my gears, Auburn Carrier, Hypertech 160 Degree Thermostat, SLP Strut Tower Brace, Sub Frame Connectors, Throttle Body Bypass, Powerslot Slotted Rotors, Hawk Performance Brake Pads. Best 1/4: 13.192 @ 106.38MPH w/2.086 60' on GoodYear Eagle F1 tires. Recent 1/4 run on 4/10/02: 13.502 with a 2.367 60' on 275x40ZR17 Dunlop SP sports, without the 160 thermostat, STB, SFC, or TB Bypass--With Some DR's, maybe run a 12.8, or 12.7? Fingers crossed. Headers coming soon. See "Cammie" at http://members.cardomain.com/ozorowsky |
it prolly won't help you any. if it does it'll prolly just make it a little louder if it even does that. corsa's are good exhaust that don't need much help.
A cutout will gain over a catback. Might not be much. Maybe 2-7hp depends on the catback and flow. Remember it isnt going through a muffler.
------------------ Jack 00 Camaro Z28 Whisper Lid, 3.73s, Z06 Clutch, HPP3, Spohn LCA, PHR and Quick Time Electric Cutout |
It depends on how free flowing your Corsa exhaust is, I'm not familar with what the inside of that muffler looks like.
I know after I added FLP's to my car, the Flowmaster proved to be restriction. ------------------ 1997 Bright Red Z28 A4, 3.23's, K&N FIPK, FLP Headers, Flowmaster, Cutout My Z28 |
A buddy of mine has a Corsa cat-back on his TA with a cutout. He actually lost a little power with the cutout open on the dyno. He just opens it when he wants to be noticed http://web.camaross.com/bb/wink.gif and keeps it closed when he races.
I have a stock exhaust and could feel a BIG difference with the cutout. I will find out if I can improve upon my best 1/4 mile time (13.4) as soon as it cools off. ------------------ Jeff 98 Z28 13.4@107.3/312.3RWHP 324.9RWTQ -direct flow air lid, K&N air filter, exhaust cutout w/ McCord power plate. 99 GTP 14.6@96 -K&N air filter, 3.25" pulley, Tranny cooler, 3" int. pipe with stock mufflers. |
Maybe with just a cat back adding a cut out will only add 5hp, but he is also doing FLP headers with straight pipes. This will require more air flow. IMO a cut out will help out more in his case due to his headers.
and latter down the line cam and heads are planned. with those on there a cut out is required. |
i doubt you will see much improvement by putting a cutout on with headers and a catback. very very small gains if so, except for the decibal department. i love having my car loud, but if you did that you are going to be hunted by the hogs for sure. http://web.camaross.com/bb/smile.gif
------------------ 1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights. |
| All times are GMT -5. The time now is 09:10 AM. |
