Dtc P0128 (ect)
My car's SES light came on recently, and with Autotap's EFILive I saw that the code that it threw is DTC P0128 (ECT). I installed a 160* T-stat about 5 months ago, but now that the mornings are very cold (mid 30's in the morning here) it might be taking the engine coolant a little longer to reach the target value.
During the same reading, the ECT was about 140 degrees, at start-up ... Have any of you experienced this before? Or do you think it might be a faulty t-stat? Thanks in advance! ;) |
That DTC code is: Coolant Temp Below Thermostat Regulating Temp
I never had a problem with the 160* in mine, but who knows? Anyway, you can look up any DTC code on this site: http://www.actron.com/code_lookup/index.php |
| All times are GMT -5. The time now is 08:17 AM. |
