Cut Out Noise
Old Mar 24, 2003 | 10:13 PM
DAVID 93 Z28's Avatar
Question Cut Out Noise
AFTER I HAD MY CUT OUT INSTALLED WHEN I UNCAP IT I GET A METAL TO METAL RATTLING SOUND. CHECKED VEHICLE AND COULD NOT FIND ANYTHING WRONG. DOES ANYBODY HAVE ANT CLUE. 02 WS6 AUTO. THANKS FOR ANY HELP
Old Mar 24, 2003 | 11:18 PM
fbird95's Avatar
do you remove all the wing nuts from the studs when you uncap it? Thats the only thing i can really think of that would be obvious. A more underlying cause could be the frequencies of the cutout rattling something under the car. you would have to go under their and look for it. I know on my car i had this rattling noise after i install the exhaust and it turned out to be a metal ring that just seemed to be hanging out around the exhaust pipe after the cat.
Old Mar 24, 2003 | 11:22 PM
norcalstreet's Avatar
Where does the rattling come from?How loud? I would simply make sure all the bolts are securely tightened underneath your car. Not just the exhaust bolts.
Old Mar 24, 2003 | 11:29 PM
stik6shift98's Avatar
need a little more info
thanks
did u take a good look under there???
Old Mar 25, 2003 | 11:31 AM
I HAVE CHECKED ALL OF THE BOLTS AND HEAT SHIELDS. EVERYTHING IS TIGHT. WHEN I REV MY ENGINE ONCE THE RPMS START TO COME DOWN I CAN HEAR THE NOISE OR WHEN IM DRIVING RIGHT BEFORE THE CAR SHIFTS,. I JUST INSTALLED A ELECTRIC CUT OUT TODAY AND THE NOISE IS THERE IF I OPEN CUT OUT AT ALL. NO NOISE AT ALL IF ITSW CLOSED
Old Mar 25, 2003 | 11:33 AM
JDHarris's Avatar
Okay, does the sound only occur when the engine is dropping in RPM, like if you rev it or if you're driving along and put the car in neutral, or does it happen all of the time? If it only happens when the RPM is dropping, it's normal. Every LS1 with a cutout I've listened to has done it. I believe it is caused by a valve fluttering up closer to the engine. I don't recall which valve, but I saw somewhere a write-up for putting a restrictor on the valve to reduce the problem. It is a rather disconcerting noise, but it doesn't hurt anything and there is no rubbing.
Old Mar 25, 2003 | 07:22 PM
TooMuchZ28's Avatar
Are you using the one's from FTForce.com? Mine made noise but I just didn't tighten it enough.
This is not an electric cutout right? Just the regular flowtech?
Old Mar 25, 2003 | 08:57 PM
I PURCHASED THE CUT OUT FROM SUMMIT AND DIDNT UNCAP THE CUT OUT TIL A WEEK AGO. MADE THE NOISE AS SOON A THE CAP CAME OF AND I REVED THE ENGINE. SOUNDS LIKE METAL IS BOUNCING AROUND .INSTALLED ELECTRIC CUT OUT AND SOUND IS STILL THERE THANKS FOR ANY HELP.
Old Mar 25, 2003 | 09:14 PM
JDHarris's Avatar
Yup, see my last post on this thread. It's normal with a cutout. Nothing is actually rubbing, it's the valve fluttering.
Old Mar 25, 2003 | 11:31 PM
THANKS FOR THE HELP GUYS. GUESS IM JUST GOING TO LEAVE IT CLOSED MOST OF THE TIME. ALWAYS HAVE MY 93 Z28 OPEN AND IT SOUNDS THE WAY I WANT MY WS6 TO SOUND.
Jeff1904
Jun 5, 2016 05:00 PM
colts0455
Oct 4, 2015 09:47 PM
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
