charging issues
Hi, a friend of mine has a 98 Camaro (auto), it starts, everything works, even the a/c works, but until the battery dies :( the alternator is ok, what more could it be? :confused:
I would get the battery load tested for starters, it may be something as simple as that. If that checks out, then I would check over the wiring, make sure you have good, clean, corrosion-free connections everywhere.
thanks, we are going to check that and if that doesn't works, ill be back lol..
| All times are GMT -5. The time now is 09:26 AM. |
