cam a tooth off?
it has been mentioned maybe my cam is a tooth off (based on the numbers it's giving).
Now, with .595 lift, wouldn't a tooth off be enough to cause a valve to piston clearance issue? |
Re: cam a tooth off?
Could be off a tooth advanced & open & close sooner. Usually moves the power band up advanced as well, vice-versa retardarded.
well, see this thread for my problems and see if it sounds like it could be the problem: http://web.camaross.com/forums/showthread.php?t=304350
This is just my personal opinion so take that for what it's worth. But I don't believe it would run anywhere near as good as it does if you were a tooth off. I would run crappy.
You bought this cam used. Didi you put a degree wheel on it to check the valve event timing? Maybe it was a bad grind anad that's why the guy was selling it? |
| All times are GMT -5. The time now is 08:35 AM. |
