CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   cam suggestions (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/cam-suggestions-292700/)
00pewtws6 Aug 17, 2004 10:48 AM
cam suggestions
i need help on deciding what cam to go with on my 2000 TA. i want something aggresive but i can still use for an everyday driver. and what kind of exhaust, long tubes etc. setup to go with for later....but the cam and heads are comin first.
AL SS590 M6 Aug 18, 2004 04:47 AM
Re: cam suggestions
Search
teke184 Aug 18, 2004 06:48 AM
Re: cam suggestions
headers and exhaust should be first. other wise you'll be choking the hell out of the cam...if nothing else get a good exhaust first.
how much power you looking for?
lot of guys are getting 380-390hp with cams in the 224* range with tuning on stock heads.
alot of guys are daily driving 230+ deg cams with heads....depends on your definition of "daily driver"
00pewtws6 Aug 19, 2004 11:24 AM
Re: cam suggestions
yea i was lookin for around 400 to the rear
LSUxBlake Aug 19, 2004 02:05 PM
Re: cam suggestions
I would suggest the Futral Motorsports F11. I have one, easy to drive with, nice agressive lope to it. It's a 228/230 .581 .591 112LSA . If you want even more than that the F13 is a 230/232 and is supposedly just as streetable. They'll both put down 400 to the wheels with a good tune.
Mindgame Aug 19, 2004 03:38 PM
Re: cam suggestions
That FMS cam is a nice one. Couple that with some good port work, gears and bolt ons, and you've got one mean driver.
-Mindgame
blazers Aug 20, 2004 09:54 AM
Re: cam suggestions
I have a 224/228/114 0.578 lift cam. Very streetable. 384/rwhp and 381/rwtq. Stock heads w/LT headers and dyno tune.
