CAI Packages
Old Sep 21, 2003 | 08:47 AM
SP99SS's Avatar
CAI Packages
I've seen several SS owners here who have a CAI system installed. Do these CAI packages eliminate the functionality of the SS hood scoop/intake?
Thanks,
SP
Old Sep 21, 2003 | 09:30 AM
Y2kPewterSS's Avatar
Yes it seals around the lid and pulls all the air from under the car. It is supposed to be a ram air kind of affect. I saw no performance gain at the track after installing one.
Brian
Old Sep 21, 2003 | 09:59 AM
2001NBMZ28's Avatar
There's a couple articles on the functionality of the SS hood and Fast Toys Ram Air at www.installuniversity.com
Old Sep 21, 2003 | 01:31 PM
XTZ's Avatar
XTZ
Brian
I noticed in your sig that you have the SLP CAI. With my Super Sucker(SSRA) I picked up .15 and 2 mph. I believe it's generally known that the SLP is the worst of these kits.
No you don't have to seal off the hood. You have the option of using both the scoop off the hood and the scoop under the car with the SSRA. I've tried it both ways at the track, with no difference. I think that sealing the airbox that FTRA spouts is a myth. JMHO.
Old Sep 21, 2003 | 03:02 PM
ULTIMTEORANGESS's Avatar
SLPs CAI might be the least effective but your car wont run hotter with it and its least likely of the other kits to suckup water.also if you like fast toys sells an extension for it making almost identical to other kits by having it take in air sooner.
Old Sep 21, 2003 | 04:21 PM
XTZ's Avatar
XTZ
When you say the extension that FTRA sells, are you talking about that plate that runs down towards the air dam that really covers up the radiator. Or are you talking about the scoop that's similar to the SSRA's lower scoop? How does this make them nearly identical to other CAI's.
Old Sep 21, 2003 | 04:30 PM
the part that covers the radiator more.SSRA comes all the way out from underneath the car.it takes in more but obviously hangs lower.this extension piece makes it similar to a FTRA design.
Old Sep 21, 2003 | 06:32 PM
XTZ's Avatar
XTZ
My buddy has the FTRA with the extension piece. It comes down to the air dam. My SSRA sits about 7 1/2 inches off the ground. The air dam on our cars are about 4 inches off the ground. In effect the FTRA with the extension including the air dam makes this system more susceptible to ingesting water. This is also due to the SSRA being in front of the wheels, where the air dam is about parallel with the wheels. Any splash coming off the wheels might potentially go into or be deflected by the air dam into the FTRA. I have yet to see anybody posting on any board that their SSRA caused their engine to hydrolock. I have however seen people post that they hydrolocked their engine with the FTRA.
Old Sep 21, 2003 | 06:58 PM
SunsetWS6's Avatar
The slp CAI is the worst of them all. I had the FTRA on my 01 SS & it didn't raise temps at all & it never sucked up any water. The only way any of those CAI's would suck up water & hydrolock the engine would be if you drove through a deep body of water. If it's just raining & there's water in the road you'll be fine. If I had a SS , T/A, or Z, FTRA would be the way to go.
Old Sep 21, 2003 | 07:18 PM
did you atap your car?i know for fact FTRA raises eng. temp.
Kinglouui
May 26, 2016 11:05 AM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
Z Power
Sep 19, 2015 11:19 PM
tdigger9899
Sep 7, 2015 10:56 AM
