Break in
Got mine and was easy on it for a little bit then progressively got harder and harder..
it sees the track tonight!!
3700 miles and no oil change yet! (Payday is this weekend so it will be done then!)
I was nice for mine for 100 miles or so, then once I knew that everything was cool, I let things loose a couple times before the "recommended, 500 mile break-in period" was over. I never held it at WOT during that time, but I didn't keep revs below 3000, or keep my speed below 55mph either.
The car now has 9500km (almost 6000 miles), it's had one oil change so far (Mobile 1 of course!
) and it still runs as strong and smooth as the day I picked it up. IMO, drive it how you're going to drive it --- if a motor is going to blow up, it's usually going to be within the first few miles anyways, otherwise, it's fine.
Hope that helps you out a little. Enjoy your new car!
) and it still runs as strong and smooth as the day I picked it up. IMO, drive it how you're going to drive it --- if a motor is going to blow up, it's usually going to be within the first few miles anyways, otherwise, it's fine.Hope that helps you out a little. Enjoy your new car!
Hey I ambreaking mine in too,I am taking it easy although as some else said I am getting more and more aggresive!U are going to have it for years why not take it easy for a bit?Dont worry about all those fluid changes just the oil and that is a MUST.I plan on one dino oil then to Mobil1.Good luck
Originally posted by ChrisFrez
Nope - drove it hard right from the Lot. Changed the oil at 500 miles and that's it. I don't think that cars now-a-days need to be broken in like they did a while ago.
Thanks for the help!!!
Thanks for your help guys, I really enjoy my new camaro….is there any one that owns a camaro that doesn’t beat on it!!!… Well some one has to stomp all the imports…hey if I didn’t know **** about cars I to would have bought a import. Did I mention that it is a babe magnet!!!
Eric
Eric
Aug 17, 2015 09:50 AM
