blowing fuses
Old Apr 22, 2003 | 06:33 PM
ERIK93Z's Avatar
Question blowing fuses
02 T/A I hooked up the electric cut out. Should this be hooked up through the traction control system. It keeps on blowing fuses on the electric cut out. Is it drawing to many amps/bad ground do I need a bigger fuse?
Old Apr 22, 2003 | 07:34 PM
99BlackZ28T56's Avatar
Can you unhook the wires at the cutout? If so see if fuse still blows, maybe a pinched wire.
Don't add a bigger fuse. They give you size it needs. Any higher is drawing more than it should.
I always like to tap in at the fuse box with a wire dedicated to whatever youe wiring in. This way you don't need to deal with blowing fuses on other circuits because you overloaded them.
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
