Best oil filters for LS1 ??
Old Apr 20, 2003 | 03:32 PM
steelerfan's Avatar
I've always used either Fram or ACDelco oil filters foe my cars but Ive been thinking about switching to K & N oil filters even though they cost 2 to 3 times the price,but only if they're worth it.Any opinions or other filter suggestions ??
Old Apr 20, 2003 | 03:38 PM
ZIPPERR's Avatar
Mobil 1, K&N, Ac Delco are all great filters. Just don't use fram
Old Apr 20, 2003 | 03:54 PM
steelerfan's Avatar
Now you're worrying me.What's up with Fram ? I've been using them for 10 to 15 years.If you know something I don't then tell me.I value my cars too much to use something on them that's bad for them
Old Apr 20, 2003 | 04:17 PM
Black6SpdTA's Avatar
same here man i thought fram was like the best
Old Apr 20, 2003 | 04:18 PM
ZIPPERR's Avatar
If you do a search you will find a lot of info..
Here is a link:
http://www.prostreetonline.com/pso/p...oilfilters.asp
Old Apr 20, 2003 | 04:29 PM
steelerfan's Avatar
Thanks for the web link,I found the info very illuminating,no more Fram filters for me, thanks.And here I thought I was buying a high quality filter !!
Old Apr 20, 2003 | 04:56 PM
ZIPPERR's Avatar
here's another link
http://www.ls1tech.com/ubb/cgi-bin/u...c;f=1;t=010381
Old Apr 20, 2003 | 05:06 PM
2002Z28SSConv's Avatar
And another:
www.bobistheoilguy.com
For all your oil questions related, look no further. This site is the mother load.
Old Apr 20, 2003 | 07:40 PM
Ferocity02's Avatar
I use NAPA Gold filters, seem to work pretty well.
Old Apr 20, 2003 | 08:38 PM
stik6shift98's Avatar
i use mobil 1 and have used kn before
Old Apr 20, 2003 | 08:41 PM
SFB767's Avatar
I've always used Fram, my dad has always used Fram, my uncle has always used Fram, my friend's nephew's cousin's brother has always...
Well, you get the idea.
When I personally hear about a Fram causing engine damage or messing anything in an engine up, then I'll switch.
Old Apr 20, 2003 | 09:24 PM
redz28kn3007's Avatar
AC Delco is just fine - don't waste your money. There are two filters that fit, I'm using the PF58 instead of the recommended one, it's longer but has the same thread size and o-ring diameter therefore it fits. It's not too long, it sticks slightly out but is not the lowest point underneath the car, just give it a try - a bigger filter should work better than a smaller one...
Old Apr 20, 2003 | 09:39 PM
Everybody you know may have always used Fram. But a few years back they changed their design to save money. If you want an internal construction made up of cardboard instead of metal, go right ahead and keep using Fram. I'll never buy one again.
Old Apr 20, 2003 | 11:00 PM
SunsetWS6's Avatar
Wink
K&N oil filter for me.....
Old Apr 20, 2003 | 11:13 PM
where did u find it????
i only found it one time......
