CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   Backlight bulb for stereo? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/backlight-bulb-stereo-109871/)
99_Z_155 Apr 20, 2003 09:55 PM
i need the serial number for the bulb that goes behind the display on a 99 pontiac grand prix. this is not the stereo with the equalizers, i dont know if that makes a differece. i am pretty sure i read about this somewhere on the board, how you can take the face off of the stereo and replace the bulb if the display is not lighting up properly.
stik6shift98 Apr 20, 2003 10:29 PM
try posting this in the audio section:D
99_Z_155 Apr 21, 2003 10:02 PM
I would but it seems like no one ever looks on that forum. I will just repost then i guess, i dont remember anything about what the rules say about it so i guess ill just do it. lol. if im in the wrong, i guess one of the administrator guys will tell me about it.
fbird95 Apr 23, 2003 02:15 PM
If you take the radio apart, it will never go back together the same way. The buttons will stick and it will most likely be worse off than it was before you started. I tried to change the backlight bulb in an older delco and i screwed it up good. I had to get another.
