Another LS6 install question
Old May 21, 2007 | 11:57 PM
ChicagoTransAm's Avatar
There is a large hose and a small hose connected to the back of the intake. Found where the small one connects to the intake, and where it connects to the passenger side. Now, there is a hard plastic line running off towards the driver side and I will be damned if I can find what it connects to.
It is called the "air vacuum solenoid valve" on the schematic???!?!
Old May 22, 2007 | 10:53 AM
Here is a picture of the line I am talking about...It is the line in the middle. I know where the T goes, (back of the intake/off to the passenger side. Can't figure out that long piece though!?
Old May 22, 2007 | 03:54 PM
Bayer-Z28's Avatar
It's for the AIR system.. I'll grab a pic.. It's mounted on the right side tword the rear. It connects to the electric type solenoid. Unless you're converting the coolant bypass, you'll have to grind down the underside of the intake. -Just the square spots.
Old May 22, 2007 | 04:16 PM
You're the MAN! Pretty damned sure I don't have that any longer (thus the reason I cannot find it)!!! I yanked the AIR stuff off last year when I did my headers.
Oh, and I got the intake off an 02 T/A and grabbed the lines/block offs with it, but thanks!
Old May 22, 2007 | 09:58 PM
Bayer-Z28's Avatar
^ There's your answer.. Just delete the T in the back of the intake. and plug that line into the intake that comes from the pass side.. -You need that one.. It's for the climate control.. I forgot it when I first installed the intake..
Old May 22, 2007 | 10:09 PM
Thanks so much Bayer.... you just saved me a $hit ton of headaches!
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
