CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   Another Header Question (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/another-header-question-306655/)
99Blackt/a Oct 4, 2004 11:17 AM
I've been considering getting a set of pacesetter longtubes (im broke :( ) and the dual system that tsp sells, i know ill have to get the o2 sensor eliminators but the real question is will i need to get the car tuned after the install, also should i remove the egr and air equip (i know ill need a tune after that)???
SMAX Oct 4, 2004 11:23 AM
Re: Another Header Question
just do what i did.(it will be cheaper.) get the off road headers they have no egr or air stuff. take the egr and air off your car. dont buy o2 sims. just take the car to have the egr and air codes turned off and have the rear o2's turned off. you get this done for around $75.
teke184 Oct 4, 2004 11:34 AM
if you don't have to worry about emissions, what is the point of running the EGR and AIR. and besides, the AIR system is there to help out the cats, if those are gone...the AIR is pointless.
you don't neccessarily need a tune after headers, it would probably help out to get max power out of the car, but not needed.
as for tuning if you remove the EGR and AIR, that also isn't neccessary for the car to run well. all they will do is trigger an SES light. none of which will hinder performance in any way. you just have to deal with the light being on all the time. if you can deal with that, than don't bother with the o2 sims since all those do is prevent the SES light.
and if it's already on for the egr and air, it won't matter that it's on for the rear cats
live with it till you can get it tuned....that's what i'm doing
SMAX Oct 4, 2004 12:30 PM
yeah, you dont need a tune just need codes deleted. ;)
99Blackt/a Oct 4, 2004 02:29 PM
Thanks for all the info cant wait to get them on
cocheese Oct 4, 2004 09:47 PM
Would a predator programmer take off the SES light for deleted egr and air? I'm in the same situation. Wandering whether to get them with or without emissions stuff. Thanks in advance!
Ryan
CtRw Oct 5, 2004 02:01 AM
Do you really gain anything by removing EGR? My car never threw a single A.I.R. code without it so why do I keep hearing that it does throw the code?
AL SS590 M6 Oct 5, 2004 04:54 AM
Ryan
The Predator dealer or the Diablo Sport crew can e-mail you a tune with all of that stuff deleted and any other changes that you might want. Don't know where you got your's from so I don't know what they'll charge. The person that I got mine from does it for free for his customers or for a one time fee of $100 for non customers.
