99 SS door lock
Strange problem with the new car. The drivers side doorlock will unlock with the remote(alarm) and switch, but will not lock with either.
The passenger doorlock works perfect. I will be replacing the window motor, so it will be the perfect time to check it out. Any ideas? Thanks Chris |
A similar topic can up yesterday. I would do a search. You might start out by reprgramming the key fob then troubleshoot from there. Good luck.
Cool. I will search. Unfortunately, it does not work on the switch on the door panel either.
Thanks Chris |
| All times are GMT -5. The time now is 05:18 AM. |
