CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   6th gear (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/6th-gear-47564/)
jd13 Nov 14, 2002 02:50 PM
6th gear
How often do you guys use 6th gear? Obviously it's more for highway use, but do you around town guys use it when you can? I imagine that it puts a bit of stress on the drivetrain. Just wondering if I should stay away from it, or go for it when I can.
XKnightRider Nov 14, 2002 02:55 PM
I only use it on the freeway really.
When I'm over 55mph for any length of time.
2k2z28 Nov 14, 2002 03:26 PM
I only use 6th on the highway as well.... but I only use it if I am going 70 or over.... because I like to keep my RPM's over 1700.. or else the engine does not run as smooth...
bbentley40 Nov 14, 2002 03:30 PM
I generally only use it when I am driving 70 or so. So that is normally only when I am on the highway or interstate.
SS_Thunder Nov 14, 2002 10:11 PM
I use 6th at 60mph or higher
Rd95Z Nov 15, 2002 02:18 AM
I usually shift into 6 around 60-65 mph. If I leave it in 5th at that speed, the Loudmouth can get to be a bit much.
-John :D
ssvegas Nov 15, 2002 06:41 AM
therealmagyver Nov 15, 2002 07:35 AM
I use it on the highway. Before I put my dymanx bullet muffler also known as dynomouth I used to get slight hesitation when I accelerate a litte in 6th gear. Now after the install I don't have that problem nearly as much, so now I am in 6th gear at 55. No use in the city.
WhiteDeathLS1 Nov 15, 2002 11:37 AM
The 4.10 gears make 6th gear much more useable IMO. I feel that it kind of offsets the loss in MPG due to the gearing. :)
Me In ThAt Z Nov 15, 2002 11:42 AM
You can use 6 gear a lot driving in the city at low speeds its like you are sitting at idle wasting no gas at all it works for me :)
Dark Angel Nov 15, 2002 12:15 PM
I use it on the highway and town.
