402 short blocks for under $3500.
https://www.slponline.com/img/part_img/12400.jpg
SLP will soon have very affordable 402 short blocks ready to ship with no core required! Crate-Engine-Assembly, "ZL-402" LS1 Short Block (High Compression) With GM’s versatile "Gen III" small-block gaining popularity as the foundation for a wide range of high-performance engine build-ups, market demand for an affordable LS1 stroker package has become increasingly intense. In response, SLP Performance Parts has devised a revolutionary new Gen III stroker short-block assembly, one that offers unexcelled performance and durability at a truly accessible price. Dubbed the "ZL-402" to reflect its beastly 402-cubic-inch displacement, the package is chockablock with such race-proven hardware as a new GM LQ9 block, a 4.00" forged steel crank, and 4.00" forged aluminum pistons. With the right cam and heads and a properly tuned PCM, the ZL-402 is fully capable of producing over 575 hp and a similar amount of torque in naturally aspirated form. This package is sold only in short-block form, minus manifolds, camshaft, oil pump, and other ancillary equipment. The obvious advantage of this approach is that it allows each customer to formulate a parts combination that is perfectly suited to his or her needs. (For those who prefer "one-stop shopping," SLP offers a host of uninstalled options on an à la carte basis.) Although designed primarily for use in late-model F-Bodies and Corvettes, the ZL-402 also makes a superlative choice for most street-rod, muscle-car, and truck applications. Best of all, it’s sold outright, eliminating the shipping hassles, protracted vehicle downtime, and additional out-of-pocket expenses associated with core returns. Features Built entirely from brand-new parts. Sold outright*no cores required! GM LQ9 iron 6.0-liter block (includes block plugs) 4.000" 4340 forged steel crankshaft, balanced to rotating assembly 4.000" 2618 forged alloy pistons (includes new rings and full-float pins) 402-CID displacement 6.125" I-beam rods Includes new, factory-installed cam, rod, and main bearings. 11.3:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used) Designed for naturally aspirated applications Meticulously assembled to OEM tolerances and specifications. Oil pump, timing chain, camshaft, pans, plates, and covers not included. Looking for less compression? There will also be a 9:1 version available! More details for each of these can be found on our website. We're currently taking pre-orders to provide you with one of the first that become available. They are expected to start shipping around September 1st! Our price is $3499.99 for each with NO core exchange required! |
Re: 402 short blocks for under $3500.
Wait... wait wait... They're making a high performance short block and stuffing it full of goodies, but they're using stock bearings? Great idea....
So GM bearings are crap???
moderator, the product this post takes about is an IRON block (not an aluminum ls1!) shouldn't this be moved to supporting vender area?
Alot of people use an iron block in their f-body so I figured this would be a good section to post the info. It might not be seen in the discounts section of the site.
Here are some more details - Production 6.0 block Internally balanced rotating assembly SLP sped'd Eagle 4" crankshaft SLP spec'd 4" pistons, 2618 forging (Ross or Manley). N/A version - approx - 1.2:1. Heavy duty forced induction version approx 9:1. Compression ratios are nominal, ultimate compression ratio wil depend on the heads and gaskets that are used. Assembly is meticulously assembled to OEM tolerances and specifications. Oil pump, timing chain, camshaft, pans, plates and covers not included. |
No, I'm not saying GM bearings are crap, but when people do performance builds on an engine, do they go to a dealer and get stock bearings or do they get something like Clevite77 bearings?
How will that bottom end hold up to say around 15#'s of boost with proper tuning and fuel?
I don't think they've tried it yet but 9:1 is usually pretty safe for that compression.
