3 inch Y + Borla + Stock Manifolds?!
I got the borla on order finally... but i really want a 3 inch y pipe and i have to use the stock mani's... (warrenty). Is this possible? And i will be running cats as well.
That's my setup. I got the y-pipe from SLP because that flat p.o.s. y-pipe from the factory was not staying on my car any longer than it had to. If you have some time, it might be a good idea to head over to the local exhaust shop and see how much they'd charge to fab you up a custom y-pipe. I didn't compare prices, so I still don't know if SLP ripped me off.
To get the y-pipe to fit on mine (T-Top), I had to cut the right side right behind the 02 sensor and clamp it. The left side bolted right up. I'm not 100% on convertibles, but there's a kit that SLP sells that you might have to get in order for it to work.
http://www.slponline.com/view_produc...RTNUMBER=30055
You might wanna call them and see what they say.
Jan 5, 2015 07:14 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
