16232148 ecm
HI Guys and Gals, i 'm looking for an ECM P/N# 16232148
Re: 16232148 ecm
That’s a ‘97 Corvette PCM, if I’m not mistaken. Maybe also ‘98?
Anyway, that means it’s one of the P01 family, of which there are several. They are mostly interchangeable, so long as you have the ability to do some very minor repinning and can flash it with the correct software. The “best” P01 is p/n 12200411, also known as an 0411. It was used on 01-02 Camaros and 01-03 Corvettes. If you can handle the repin and software flash, you’ll probably find more of those on the market. If you get one from a Corvette with the same transmission type (auto or manual), I think you would not need to flash the software. |
| All times are GMT -5. The time now is 08:54 AM. |
