Windshield Washer Fluid Reservoir
Hello All,
I have a 97 CamaroSS. I recently installed a front mount inner cooler. My current washer fluid reservoir now does not fit in the same location. Has any here experienced this and if so what solutions are there? Thanks in advance. |
Re: Windshield Washer Fluid Reservoir
well, do you really need it? ive had my car since april, and ive used the washer twice. if the interference is relatively small, and only with the tank, not the pump, you could make a flat cut in the tank to make it fit (the cut edges should be in one plane), then superglue some plastic across that, and use some silicone to make sure it seals
This post is somewhat old, but it is deals with the same problem I am having.
I need to relocate the wiper washer reservoir and am looking for any suggestions. Mainly thinking of using another car reservoir with a shape that could be easily installed in another place. Thanks for any suggestions |
