windshield foggy
I recently noticed that my windshield is foggy inside my camaro and I cannot figure out why it has gotten like this all of a sudden. I checked to make sure that no water has leaked in anywhere and the carpet and everything is dry. Anyone have something like this happen to them before?
Re: windshield foggy
Can you smell antifreeze in car? Sounds like heater core leaking. Maybe it's not leaking bad enough to get the carpet wet enough for you to notice. You could bypass the heater core and see if that clears things up.
or maybe its just getting cold, and youre making it fog up?
If this car's a rockin?
I dont smell antifreeze in the car and the carpet is completely dry. It seems like the windshield got foggy when the weather got colder. Today it is warmer outside and the windshield is not foggy.
Originally Posted by one bad Z28
(Post 6820533)
i thought alot of cars did this when it gets cold out lmao? every car i've owned has done this...be it the crown vic, the rx300, or the z.
all cars do it. as soon as you get in, you start warming up the car, and making it more humid by breathing. the vapor pressure of water increases with temperature, so when the warm, humid air hits the cold windshield, it cant hold all that water anymore, so it gets deposited. warming up the windshield with the heater is the only way to fix that. or some sort of anti fog coating on the windshield, which ive never seen, but would be awesome.
Originally Posted by rv93
(Post 6820846)
but yea, every car will do that when it gets cold. if you notice as well, when you turn on the Defrost, the A/C also kicks on in order to dry the air or some such. Helps it defrost that much quicker. |
