water on passenger side floor-not sure what from?
i noticed the floor on the passenger side on the right hand side (to the right of that hump) is soaked. i have no idea from what as my car is garaged and doesnt see rain
any thoughts? |
Re: water on passenger side floor-not sure what from?
heater core blew...
do a search for fixes |
Smell it to make sure its coolant before you go in and replace the heater core. It most liklely is if the car is garaged but better to be safe then sorry.
See this thread.
http://www.camaross.com/forums/showthread.php?t=296414 It's most likely a clogged hole in your evaporator housing. It was for me. Dan |
Yup. It is either the heater core or clogged evaporator hole.
Check and make sure which one it is. TS |
Thanks Its Still Udner Warranty So I Will Take Back Unless It Is Easier/cheaper For Me To Fix It Myself (cause I Would Be Without My Wheels!)? How Much?
Hey What Is That Hump On The Floor? |
The hump on the passanger side floor is where the exhaust is routed. Its there cause the car is to low to have the exhaust hang any lower so they just pushed it up into the floor boards.
Originally Posted by falchulk
Catalytic converter to be exact.
The hump is a leftover from the 3rd Gen floorpan. GM saved money and used same/similar floorpan as in the 3rd Gens. TS |
Originally Posted by 95GRNZ
Yup, but which is/are actually not even located under the hump itself.
The hump is a leftover from the 3rd Gen floorpan. GM saved money and used same/similar floorpan as in the 3rd Gens. |
I hate that hump, Im glad I dont have to sit there.
Originally Posted by LT4Firehawk
Actually, the 93-95 fourth gens had a single cat directly under that hump. In 96 they went to dual cats that were no longer under the hump, but they didn't redesign the floorpan do to cost.
will it hurt my car to drive a day or two before i get fixed? i wont run the ac and its too damn hot for heat!
i dont think it will hurt ur car at all, just my opinion tho, wait till others reply
