Ignition stuck in on position
Old 06-30-2018, 11:55 AM
MasterMason623's Avatar
Good day. Long time lurker, rare poster.
my 2001 T.A. ignition is stuck in the on position. Car will not shut off and I can't remove the key.
had to dump the clutch and disconnect the battery.
I've wiggled, jiggled, beat, banged, shok/turned the wheel....its stuck.
can I skip/override VATS and ignition and put in a start button and kill switch?
not concerned with theft.
not a daily driver.
2001 T.A. M-6
thanks in advance for any help
Chris
MasterMason623 is offline
Old 06-30-2018, 06:44 PM
Re: Ignition stuck in on position
The key cylinder connects by a rod to the ignition switch closer to the bottom of rhe steering column. Perhaps the switch is jammed. If that's the case, you may be able to disconnect the rod from the switch, and then see if that frees up the cylinder. If not, the switch is stuck and can be replaced. If it’s actually the cylinder, may be a way to access the cylinder and remove it.... not sure about that part.
This article on replacing the switch has photos that should clarify how all the parts fit together.
Courtesy of Shoebox
4th Gen F-body Ignition Switch Replacement
Injuneer is offline
thoreightysix
07-20-2013 07:36 PM
JasonK94Z
07-03-2009 02:01 PM
TobyZ28
08-20-2007 10:58 PM
SilverFormula
08-05-2004 09:08 PM
squid
Classic Engine Tech
09-10-2003 07:57 AM
Quick Reply: Ignition stuck in on position
