thought i had car fixed
so i thought i got the car fixed because of my so called "mechanic" said he got it to run but, truthfully he is an idiot and now says he has to find the timing on the optispark? i read on the forums that there is no timing for the optispark and he wants me to find out for him... what should i tell him? im having definately a timing issue. i also printed out shoeboxs 1993-1994 f body optiuspark picture to where it has to be keyed and also the lt1 crankshaft gear picture. would that help this mechanic set the timing? If im wrong please correct me but im pretty sure the only thing that needs to be set is the harmonic balancer right? which is why i printed out the lt1 crankshaft gear picture to help him.
Re: thought i had car fixed
Shoebox's picture, showing the correct engagement of the odd tooth on the splined shaft with the matching odd tooth in the hole on the cam sprocket is all you need.
If all he did to replace the Opti was unbolt the damper (it is NOT a balancer) from the hub, he just needs to align the holes in the damper correctly with the three holes in the hub. The holes are not evenly spaced, so it can only go together one way. |
Originally Posted by Injuneer
(Post 6967916)
Installing the splined teeth correctly sets the timing correctly.
While it ran, did it run smoothly? What brand Opti? After it stopped, did he scan it for codes? |
(Post 6967919)
What year car vs P/N of the distributor?
In his earlier post, he indicated he has a 94. Hence the reference to Shoebox's photo for the 93-94 Opti drive mechanism.
https://www.camaroz28.com/forums/gen...-880628/page2/ Of course in his earlier post he indicates he replaced the ICM (twice) and after the second one, the engine ran fine. Sure is confusing. Always easier if people would add a "Signature".... interesting to note that I am the only one in this thread that bothered to set on up. https://www.camaroz28.com/forums/lt1...nature-879835/ |
(Post 6967932)
Simply setting up the year, model and trans would help. You caused a huge amount of confusion posting a video of a different year. People want to help you, but they shouldn't have to ask or guess the year of the car.
(Post 6967943)
That's not a signature - did you read the link I posted? It explains how to set up a "Signature" in your "profile". That way it gets appended to every post, automatically, so you don't have to type it like you just did above.
See the fine horizontal line right above "Fred", below? Everything below that line is my Signature. I don't have to type that in every post. The system adds that. |
okay i fixed that. So What do you think is my problem with the car?
'94 aluminum head LT1s use the spline drive correct? I thought it might be an issue of the pin drive not being out far enough to precisely position the disc, but that's out. Let me see if I can find ma favorite opti class...
Here it is youtu.be/lFCjaz6zHfc watch this and the associated videos to the right. Only difference is like I said, I think 94 camaros are spline drive whereas the one in the video isn't. |
You indicate you have a mechanic that is going to install the Opti. Get that done and see if it's any better. Given the fact the mechanic seems to lack basic understanding of the Opti, it's hard to tell where this is going.
(Post 6967993)
