temp gage not working 95 bird
Hello! I have a 1995 firebird with a 3.4l v6. Recently I had my timing chain repaired and a week or so after, my temp gage stopped working. It just lays at the minimum. So I replaced the thermostat, coolant temperature sensor, coolant sending unit switch sensor, the gage relay(like replacing the gage cluster but individually, which aslo caused my oil pressure gage to stop working), I inspected the wires and fuses. And NOTHING. I'm not sure what to do anymore. It used to work...help?
Re: temp gage not working 95 bird
"CamaroZ28.com Podcast" isn't the best forum to post technical questions. Let's move this to "General 67-02 F-Body Tech".
Is the SES lamp on? Are the fans running all the time? If either is yes, have you had the PCM scanned for trouble codes?
