T-top help before the hurricane comes!!
Old Aug 29, 2006 | 05:59 PM
crazypurgatory's Avatar
Question T-top help before the hurricane comes!!
This is for my 1997 Camaro Z28.
My T-tops are leaking I need to know what I can do to stop or limit the water from coming in.
My seals are fine the little passages in the seals are not blocked up so the should be draining the water out.
I am getting water in the plastic panel where the T-top handle is then it seeps out.
What's the problem?
What can I do?
I don't want to put foil tape on it because I don't want to hurt the paint or the seal around the side's of the T-tops.
Thanks for any help toy can give me.
Chris G.
Old Aug 29, 2006 | 06:54 PM
Dave89IROC's Avatar
Re: T-top help before the hurricane comes!!
try adjusting it?
if that doesn't work, for the hurricane, just run some electrical tape over the seams around the top, it will work, and stay on, and there will be very little residue when you remove it
Old Aug 29, 2006 | 06:56 PM
Originally Posted by Dave89IROC
try adjusting it?
Well I don't know how to adjust the T-top's But I can try the tape.
Chris G.
Old Aug 29, 2006 | 07:06 PM
oneslowz28's Avatar
remove the plastic thats over where the pins go then adjust the brackets and your done
Old Aug 29, 2006 | 07:31 PM
Lightbulb Re: T-top help before the hurricane comes!!
I will have to try that after the storm.
I put some electrical tape over them for now.
I hope it helps.
Thanks,
Chris G.
Old Aug 29, 2006 | 07:43 PM
miaminick's Avatar
Dude, Im in Miami, youve still got time. Toss some tarp over the sucker and cinder block it down where the tarp meets the ground, of possible.
Or, Take a utility bag and tape it over the leak. Then take out a big towel, cut a little hole in all four corners, and tie it down to each wheel/tire.
Oh and, Ive got a whole in my Convertible top, so... I had to brainstorm today lol
HibachiZ28
Nov 6, 2015 12:53 AM
Z Power
Sep 19, 2015 11:19 PM
WPHIG2
Aug 27, 2015 06:37 AM
TGGodfrey
Aug 17, 2015 08:43 PM
