So I went to remove my AC yesterday...
Old Mar 12, 2008 | 04:30 PM
IROCThisZ28ForLife's Avatar
So yeah, went to drain my AC yesterday, and umm yeah, I wouldnt drain...I had a rag, and a screwdriver, and pushed in the valve, and nothing...What am I doing wrong
Before you post dont say take it to a professional, because the car wont be moving for at least 2 months, so yeah...
ANy ideas??
Old Mar 12, 2008 | 04:33 PM
km9v's Avatar
Maybe you had a leak? Why were you draining it in the first place?
Old Mar 12, 2008 | 04:34 PM
Im trying to remove it
Old Mar 12, 2008 | 04:36 PM
km9v's Avatar
I guess I should have read the title. Perhaps you had a leak, did it work earlier?
Old Mar 12, 2008 | 04:40 PM
Yeah, before I removed it...well started trying to it blew ICE cold...Kinda hate having to lose it but W/E
Old Mar 12, 2008 | 06:49 PM
euforia51's Avatar
Dayum... look at that engine bay!
Old Mar 12, 2008 | 08:04 PM
lol, its not mine....lol
no one has any info on this? should i slowly lossen the nut that connects it to the cabin?
Old Mar 12, 2008 | 08:30 PM
mr_camaro96z28's Avatar
there is a low and high side hook up did you try pushing on both schrader valves? Try that first and if you get nothing you prob had a leak and there is no more refrigerant in you system. At that point you could start slowly unscrewing it just be careful. I have never heard of those getting clogged in any way and if they move then their working. If they were clogged then your compressor would get crap in it and have shelled already.
Old Mar 12, 2008 | 08:44 PM
dangalla's Avatar
just disconnect a line, it wont hurt you. it may scare you though
Old Mar 12, 2008 | 09:55 PM
yeha i tried pushing both valves, but not at the same time...hmm, gotta try that, are you guys using any tool in specific to drain the valve? i used a flat head screwdriver and nothing, if not i'll loosen one bolt and see what happens...
Old Mar 13, 2008 | 01:47 PM
BigBadBlack93Z's Avatar
get a schrader valve removal tool, you can do it w/ a sharp pair of needle nose. If nothing is coming out then nothing is in there. just back the manifold bolt off from the compressor about a 1/4 turn and it should release whatever else was in there.
Old Mar 13, 2008 | 04:20 PM
ok cool, ill try that later on today
Old Mar 29, 2008 | 04:36 PM
i know its a dead thread, but wanted to say thanks guys, i took it off today from the thing by the windshield, dont know the exact name, both lines are out...
Old Apr 1, 2008 | 12:49 PM
SNOTGREEN's Avatar
Hey hate to bring up your old thread, but did you have any other issues of consideration before removing the entire ac system? I have that to do coming up real soon. The system has already been evacuated. Such things as, aside from either a blower or ac delete pulley, is a different bracket needed etc? Thanks.
Old Apr 2, 2008 | 04:45 PM
you just need the a/c delete pulley, it comes on the required bracket, and may be a diff belt size, im not sure...
