Smoke from steering column?
Subscribe
Oct 10, 2008 | 04:47 PM
Sorry I didn't know where to post this, but I experianced smoke from the steering column today. It was just a small stream of smoke and it didn't last long.
I still have turn signals and a horn and high and low beams and it still starts and runs....
Anyone have a clue what could be happening?
Reply
Oct 10, 2008 | 09:31 PM
Yeah, you got a wire that is shorting/grounding out (probably chafed insulation). I'd be trying to find it, if I were you.
Reply
Oct 10, 2008 | 09:54 PM
Quote: I'd be trying to find it, if I were you.
and quick before you end up with a pile of ashes....
Reply
Oct 10, 2008 | 10:24 PM
Probably not a bad idea to disconnect your battery until you can find it. At least then there won't be power running through the lines putting you at risk of finding your car in a pile of ashes and melted plastic when you wake up in the morning.
Reply
Oct 10, 2008 | 10:28 PM
I would try everything and see if it works, sniff around......it shouldn'e be hard to find.
My headlight switch burned up in my truck a few weeks ago.....and I lost all my lights on my enclosed trailer and truck in the middle of the night
I took it out and rigged it up to get home.....lucky it didn't burn down. Then I fixed it and traded the truck
Reply
Subscribe
