Smog pump check valve
Old 07-28-2016, 08:24 PM
joepin's Avatar
trying to get bad check valve off , used propane torch still no luck . any ideas?
thanks 1996 z-28
joepin is offline
Old 07-28-2016, 09:02 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Smog pump check valve
One on my 98 was "impossible" to remove also. I removed the pipe from the exhaust manifold, cut a slot in the end of the valve with a hacksaw and it loosened enough to unscrew it. But my car has an LS1 and the connection of the pipe to the manifold is easier to disconnect. If you can't remove the pipe, you could use a cut-off disk to cut the slot. But don't go so deep as to seriously damage the pipe threads. The piece in the photo was cut off the valve first for better access with the saw.
GaryDoug is offline
Old 07-30-2016, 12:14 AM
joepin's Avatar
thanks thats what i did cut with wheel ,replaced valve and hose works fine now no codes
joepin is offline
collinhawks
07-31-2016 07:31 PM
94Z28LS1toLT1
05-12-2016 09:28 PM
Brad Back
05-09-2016 09:41 PM
supercharged94Z28
05-08-2016 08:53 AM
Quick Reply: Smog pump check valve
