Sandblasting the intake....
Can i sandblast the intake, or do i have to be beadblast it?
I painted it red and do not like it very much. I am going to polish it, so i need to get is as clean as possible :) Thanks Marcin |
Either will work.
bead would be a much better choice on the aluminum intake.
Originally posted by plappo bead would be a much better choice on the aluminum intake. I noticed that the machine shop that blasted mine also "roughed up" the injector holes a little. Do those need to be polished-like? |
If you're going to polish the entire intake I'd sand blast it and then glass bead blast it. If you want a look close to polished but w/ much less work, you could have it ceramic coated.
