Safe/possible to drive?
Old Jan 28, 2008 | 08:05 PM
rickjames343's Avatar
will it be possible to drive my car with the 383 in sig with the stock stall and injectors? Not racing it, just slooooow driving around town to break it in and rack up some miles?
Old Jan 28, 2008 | 09:48 PM
mrmint69's Avatar
Yes its possible, but if its my car i would wait for the tune with bigger injectors. It must be hard letting it sit but its even worse just driving slow with no wot runs. My friend went for a slow breakin drive that took all day so he could race it as soon as possible.
Old Jan 28, 2008 | 09:55 PM
I could buy the injectors if needed, but it'd be driveable with a stock stall? That was my main concern.
Old Jan 29, 2008 | 05:30 PM
matLT1's Avatar
You will be fine with the stock stall speed. However, I would make sure to have the proper injectors and tune for the new setup prior to starting it. If the injector is too small, you risk the chance of running lean. If you install the large injectors without a tne, you will run rich and risk washing of the cylinder walls.
Old Jan 29, 2008 | 06:09 PM
2000GTP's Avatar
Stock stall, you should be fine. The driveability aspect may suffer some, but that is it. But as mentioned, stock injectors and a stock tune is asking for trouble.
Klypto
Mar 23, 2016 09:05 AM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
