RPO codes, gone mad...
Hello all...... I just wanted to clear this out... These codes are on my '97 WS6 M6 Trans AM.... Few that I did not find anything about, like: R8V, 6AB and 7AB...
This is my car:
AAA FACTORY TINTED WINDOWS
A31 WINDOW, POWER OPERATED, SIDE
AH3 ADJUSTER, 4-WAY MANUAL, DRIVER SEAT
AK5 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AQ9 SEAT, FRT BKT PASS DRIVER RECL
AU0 LOCK CONTROL, REM0TE ENTRY
AU3 LOCK CONTROL, SIDE DR, ELEC
CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
C49 DEFOGGER, RR WINDOW, ELECTRIC
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DE4 SUNSHADE, REMOVEABLE HATCH ROOF
DG7 MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DL5 DECAL, ROADSIDE SERVICE INFORMATION
FE2 SUSPENSION SYSTEM, RIDE HANDLING
FE9 CERTIFICATION EMISSION, FEDERAL
GU6 AXLE REAR, 3.42 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
IL2 TRIM INTERIOR DESIGN
J65 BRAKE SYSTEM, POWER, FRONT AND REAR DISC
KG9 GENERATOR, 140 AMP
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
LT1 ENGINE, GAS, 8 CYL, 5.7L, MFI, HO
MM6 MANUAL 6-SPEED BORG WARNER , 65MM, 2.661ST, 0.50 6TH, O/D
MN6 TRANSMISSION, 6-SPEED MANUAL (MERCHANDISING OPTION)
NF2 EMISSION SYSTEM, FEDERAL, TIER 1
NP5 STEERING WHEEL, LEATHER WRAPPED
N66 WHEEL, RALLY TYPE , VARI
PBT TEMPORARY HOOD, UPGRADED BY ASC
QFK TIRE, ALL, P275/40ZR17 PERFORMANCE SPEED-RATED
R8V
STE PLANT CODE - ST. THERESE, PQ, GM OF CANADA
T43 SPOILER, RR
T78 HEADLAMP CONTROL DELETE
T96 LAMP, FOG
UB3 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM
UK2 LEVER DIRECTIONAL SIGNAL, INCLUDES MULTI FUNCTIONS
U76 ANTENNA, WINDSHIELD, RADIO
VM3 LABEL, CONSUMER, CONTAINS BPR IMP STANDARD
V73 VEHICLE STATEMENT, USA/CANADA
WS6 PERFORMANCE PACKAGE, SPECIAL (Ram Air Package)
WS9 MODEL CONVERSION, FORMULA
W55 ENTERTAINMENT SYSTEM – "MONSOON" ETR AM/FM STEREO, COMPACT DISC, EQUALIZER, REMOTE CD PREWIRING, 10-SPEAKER SYSTEM – COAXIAL
Y82 MERCHANDISED PKG, TRANS AM
1SA OPTION PACKAGE 01
48U EXTERIOR COLOR DARK GREEN
52I INTERIOR TRIM, LT NEUTRAL (I) (92)
522 TRIM COMBINATION, LEATHER, LT NEUTRAL (2) (92)
6AB
7AB
8HS COMPONENT RR LH COMPUTER SEL SUSP
9HS COMPONENT RR RH COMPUTER SEL SUSP
This is my car:
R8V
T43 SPOILER, RR
T96 LAMP, FOG
6AB
7AB
