Push start button?
Push start button?
Did anyone ever really find out how to do this? I know most likely the key would have to be in the ON position but its cool as hell turing on your car with the push of a button. Any kits or instructions on how to do this?
Re: Push start button?
All you have to do is run one wire to each side of the starter solinoid....and yes the key must be on in order to start your car........ I'v had to do this for a temp fix for a bad solinoid before...you can get a push botton from any auto store for less than $10......good luck....
Do you mean like a positive and and ground wire?
It is pretty cool, a lot of gas station attendants ask me how I started my car. They fill the tank and dont see my hand turn a key and I get the same reaction every time. Definitely a good, cheap, and easy mod if you have the time and ability to do it.
I have had a push button switch in my toolbox for over 20 years for turning over an engine from outside while alone. Put +12VDC to the small wire on a GM starter and the motor turns over...it's magic. Older cars used to have two small wires on the starter...one from the switch and one to give the ignition full voltage during startup.
Originally Posted by shoebox
If you can read a schematic, it should be easy to figure out. If you cannot, you are going to need explicit instructions.
Instruct away.............Please!
Not trying to be snotty about it, just not something I am interested in. It's more at home on race car dashboard.
1stz28: I've had a remote starter switch in my toolbox for as long as I can remember. Just the thing for setting valve lash with solid lifter cams.
But would that by pass the acctual starter circut on the key. I think it would be a great anti-theft device if you could find an easy accesable nonvisable place to mount the button.
Honda pushbuttons on my car? NEVER!
