problems with convertable top
i own a 95 z28 convertable, my problem is my top wont more anymore.
a few weeks ago you can hear the motor for the top and now you cant. please help me. what do i need to replace to get it going again. thank you red camaro girl :confused: |
Re: problems with convertable top
Well, there's a variety of things that could go wrong... The switch could fail, there could be a break in the wiring, or the pump could be bad...
I'd get a standard multitester and check if you are getting 12v at the pump when you have someone press the switch for the top... The pump is in the trunk on the driver's side under some carpet. If you are getting voltage, then it is likely the pump that has gone bad. good luck, Steve Edit: Check your fuses before assuming it's the pump... |
