problems with cigarette lighter
need ur help guys. the other day i yanked out my radar detector because i was being pulled over :mad: now the lighter isnt working. The horn workes so i guess that means it not a fuse? What should I be looking for, checking? thanks for ur help
Josh |
Check to see if it's the actual lighter or if it is the lighter "socket". Plug an accessory into the socket to check this (if it works, lighter itself is broke :) ).
Or, are you trying to say your detector no longer works in the lighter socket? If that's the case, try the actual lighter to see if it works :D |
