Power Passenger Seat in Camaro - CamaroZ28.Com Message Board
Old 09-24-2005, 11:04 PM
ZeeVert's Avatar
I had a little too much time on my hands today and installed a power seat on the passenger side of my Z. I always wanted to do it, and heard other people were interested, but I never heard of anyone doing it. Well, it's done.
It took several hours and isn't a job for the the casual wrench.
Here's some pictures:
Close up
Seat installed
The Car
Has anyone else given it a try?
ZeeVert is offline
Old 09-25-2005, 09:33 AM
Re: Power Passenger Seat in Camaro
But that adds weight
On a somewhat related note... I'd rather delete the power seat on my driver's side.
That looks good though! Nice install!!
flatlander757 is offline
Old 09-25-2005, 01:06 PM
ZeeVert's Avatar
Thanks, but Hey! It's a convertible... It's already over weight.
Good point though... I could have weighed it before I installed to see what the penalty is.
ZeeVert is offline
Old 09-25-2005, 01:17 PM
2000GTP's Avatar
Probably a penalty of 10-15 lbs., not the end of the world. It looks good though.
2000GTP is offline
Old 09-26-2005, 05:45 PM
crazypurgatory's Avatar
Question Re: Power Passenger Seat in Camaro
Close up
Seat installed
The Car
How the heck did you do that?
That look real good.
What parts did you use?
And from what car?
Chris G.
crazypurgatory is offline
Old 09-26-2005, 05:52 PM
Looks Good!
93LT1355 is offline
Old 09-29-2005, 12:56 AM
ZeeVert's Avatar
And from what car?
Chris G.
Since you asked...
I used the power mechanicals from a 98 Camaro driver's seat. It came with the switch and switch cover.
The pass seat bolts right up to the track, but the track needs to be modified to bolt to the floor. (grind, cut, hammer)
The switch and wires reach the right side of the seat OK. There are a couple wires that need to be switched to make it match the seat movement. (otherwise up is down and down is up).
Run power with a 10amp fuse.
The switch cover or bezel is a driver's cover turned upside down and trimmed to fit (hack saw, belt sander). The gray is actually a nice contrast to the black seat and trim.
Beat the floor a little, trim a little carpet, curse the Cat hump, and in she goes!
It wasn't a simple job, but it can be done.
ZeeVert is offline
Old 01-07-2019, 03:16 PM
Well, ZeeVert... Don't know if you are still out there... I know this post was from 2005... But I found it 14 years later and managed to replicate your great work in my 2002 35th Anniversary LE (14,000 miles) Like you said, it took some modifying to make things work and reversing some things but it wasn't impossible.. and it went in pretty smoothly overall.
If you are still out there, thanks !!!!
CDN35thSS is offline
F'n1996Z28SS
04-02-2015 11:02 PM
bossco
11-29-2014 11:18 AM
siguy
11-27-2014 11:07 AM
DubbyZ28Camaro
08-04-2002 01:53 PM
Quick Reply: Power Passenger Seat in Camaro
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
