Pillars
#16
Re: Pillars
Originally Posted by Randy Molkentine
Injuneer which gauges do you have in the A piller and which ones do you keep in the vents? Just trying to get a feel on the best way to lay mine out. Also what size gauge do you use in the 3 vents? How did you secure them? Thanks,
Randy
Randy
http://members.aol.com/InjuneerZZ/GageDash.htm
#18
Re: Pillars
Pillar:
-2-1/16" engine oil temp (electric)
-2-1/16" tranny temp (electric)
The 2-1/16" gauges are generally only 1/4-sweep (the needle moves 90-degrees) and the hash-marks are coarser, so you put the gauges that need the least accuracy in the pillar.
http://cjcfo.fbody.com/members/injun.../DCP04162a.jpg
Center A/C vents:
-2-5/8" Nitrous pressure (mechanical)
-2-5/8" Fuel pressure (electric)
-2-5/8" Oil pressure (mechanical)
With the larger gauges you get a full-sweep (270-degrees), and finer hash-marks. Easier to read between the lines
http://cjcfo.fbody.com/members/injun.../DCP04239a.jpg
I also have:
-5" 8,000rpm Tach on top of dash
-ScanMaster LT on top of steering column
-Real time readout of all sensors and ECU parameters from the MoTeC on a laptop (optional).
http://cjcfo.fbody.com/members/injun.../DCP04241a.jpg
http://cjcfo.fbody.com/members/injun.../DCP03652a.jpg
You just can't ever have enough information........
Center A/C vents:
I also have:
08-05-2015 08:35 AM
2QUIK6
07-02-2015 07:02 AM
05-01-2015 01:14 PM
