Overheating and at a loss!
I've had this 1995 "Zr28" Camaro for roughly 3 years now, and it's finally giving me a pretty intense issue. This week, it's been overheating pretty bad (max ~200s riding to work and 230 parked). I took it to three separate shops and nobody can read my computer, since they don't have the correct ODB device. After a thermostat and fan relay change, the diagnosis is that the fans won't spin up, even when the computer is telling it to. I've done voltage checks and even bypassing the relay with wires didn't do the trick. I'm trying my best not to go get a full rewiring done, even though there is one wire that burned itself apart. Tried to patch that wire and it burns up again and again, so this is where I'm stuck. Is the wire the cause of my overheating problem?
Re: Overheating and at a loss!
Did you check the fusible link in the red wire from the red plastic “+” box near the battery, that supplies power to the fans? See the “late production” 3-relay schematic (courtesy of Shoebox): http://shbox.com/1/fan_schematic_1995.jpg Do you have 12-volts constant (key on and off) on the red wire/circuit 402 at pins D1 and F4? Best way to access the PCM, read codes, read sensors and PCM parameters is Scan9495, free scanning software. Link to download here: https://www.camaroz28.com/forums/com...95-lt1-874306/ You need to make or buy the correct 16-pin cable for your 1995. The author of the software (GaryDoug) is a Member here, and can answer question on the install, etc. |
I’d consider the burning wire to be a symptom, not a cause. Seems like there’s a short through it. What’s a ZR28? (EDIT: googled it. An upgrade package once offered by LG Motorsports. Not significant; the car is a Z28 for our purposes.) |
Originally Posted by LawlessZr28
(Post 7001935)
Doing this test showed that there wasn't a 12v supply reaching the box. Testing D1 gave a floating value of about 0.3 volts. After a continuity test between the split wire (past the red '+' box) it was connected to the D1 pin on my fan relay plug. I'll post pictures of the wire in another post. (Edit: The relay pin D3 has the 12v. Also the F labeled relay welded itself to the box and I cant remove it. What does this mean?)
Here is a picture of that split wire. The box is getting 12V, but this wire burns up every time it is patched even with the same gauge of wire.
https://cimg3.ibsrv.net/gimg/www.cam...63688cf98f.jpg |
(Post 7001946)
The photo shows it’s the fusible link, or someone substituted a piece of wire for the link. |
Don't replace the link with a piece of wire that is the same size, Get a new link. The link will have a smaller size wire inside to prevent the type of damage you are seeing. Of course the new link will open with the short that is obviously present. So you have to find and fix that first.
