Only 1 tire going bald!!
Old Apr 21, 2005 | 07:07 PM
fre$h's Avatar
sup guys, i have a 96 z28 m6, and ive noticed that only the drivers side rear tire is going bald. the passenger's side is still intact.
Is this normal?
Old Apr 21, 2005 | 07:38 PM
Kataklysm's Avatar
Re: Only 1 tire going bald!!
Quit spinning the tires Also, you may want to post this in general tech.
Old Apr 21, 2005 | 07:43 PM
PipesTA's Avatar
One wheel pealer? Also might want to check your tire preasure
Old Apr 22, 2005 | 05:32 AM
Kataklysm's Avatar
You may want to try and diagnose the problem instead of replacing an expensive part like the differential. Jack the car up and spin one of the wheels, the wheel on the other side should turn in the opposite direction.
Old Apr 22, 2005 | 08:32 AM
codyss's Avatar
Is it going bald or are you burning it off?
Old Apr 22, 2005 | 04:19 PM
CrabhartZ28's Avatar
perhaps he simply means wear on the one tire?
If you make a bunch of turns, and floor it, i could see that happening.
do you have a stock diff?
Old May 3, 2005 | 03:40 PM
wogert's Avatar
Actually, with limited slip differential, the tires should spin the SAME direction. To properly check limited slip, both tires should be off the ground. You will need a strong friend to hold one wheel, while you try to turn the other wheel with a torque wrench. I dont remember the exact slip-torque (torque reading before the diff. finally breaks free), but it should be pretty high. It should be easy to find the torque spec. with some simple research.
Old May 3, 2005 | 04:29 PM
TraceZ's Avatar
I'm surprised nobody has posted the obvoius...
Change the fluid and make sure you add the proper limited slip addative. Without the addative it does not work right and you will have one tire spin.
Old May 3, 2005 | 04:56 PM
wogert's Avatar
Actually this is a very popular misconception!!!!!!
The additive conditions the friction discs and helps them to SLIP!! Without the additive you tend to get "wheel hop" when going around corners.
At the dealership, we used to get guys that would add 2X or 3X the recommended amount of additive, thinking they were boosting the differential performance, when actually they were diminshing it!! LOL!!
Old May 3, 2005 | 05:42 PM
TraceZ's Avatar
I learned something new today. Thanks!
Old May 3, 2005 | 10:00 PM
)2overt SS's Avatar
Is there any specific wear pattern? (e.g. the edges are worn more than the center)
Or is it uniformly worn?
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Jul 4, 2015 03:06 PM
