O2 sensors
Old Nov 5, 2005 | 09:19 PM
TJ Chapman's Avatar
O2 sensors
I'm removing my stock Y-pipe for my header/y-pipe install.How do you remove the O2 sensors from the exhaust pipe and/or manifolds? I wrenched on the nut that seems to hold it in, but no dice! I just stripped the hex shape right off. Is it supposed to just unscrew, or is there some trick? So now I just unplugged it to get the pipe it's in out, but I still need to get it out eventually. HELP!
Old Nov 5, 2005 | 09:45 PM
Re: O2 sensors
If you stripped the hex, then there is little you can do but to grip it with anything you can. They make a special socket to remove them.
Old Nov 5, 2005 | 09:50 PM
Jeremy_30th's Avatar
Re: O2 sensors
Only option now is vicegrips. goodluck
sockets are great the have a slit down the side for the wiring so it isnt in your way.
Old Nov 5, 2005 | 10:32 PM
CamaroSS30thAnn's Avatar
Re: O2 sensors
vice grips and some leverage , also heat up the pipe to expand it
Old Nov 6, 2005 | 08:24 AM
2000GTP's Avatar
Re: O2 sensors
The sensors can be a real pain to get out, it might be easier just to buy a new set of 02 sensors...I paid less then a 100.00 for my two front 02 sensors.
Also, what kind of headers are you running? If you are going to use long tubes, then you are probably not going to have the post-cat (rear 02) sensors anyhow so there is no sense in struggling to fight them out of the y-pipe.
Old Nov 6, 2005 | 03:08 PM
valter's Avatar
Re: O2 sensors
Heat the pipe/manifolds. It will be 10x easier to remove them.
Old Nov 6, 2005 | 07:08 PM
TJ Chapman's Avatar
Re: O2 sensors
I am running LTs, but I'm retrofitting some pypes cats, and rear O2 sensors in the 3'' y-pipe. I need to pass the sniff test, and I also cant have the trouble codes from missing 02 sensors. (emissions)
but yeah i'll prolly buy some new 02s from somewhere
Old Nov 6, 2005 | 07:31 PM
2000GTP's Avatar
Re: O2 sensors
Sounds like you are doing what I did. I didn't run rear 02 sensors though...I wonder if I would still get a check engine light anyhow considering how small the converters are that I am running. The only reason they are there is to pass the visual inspection if one was ever to be done.
Old Nov 6, 2005 | 07:50 PM
TJ Chapman's Avatar
Re: O2 sensors
doesn't getting rid of the rear 02s make the check engine light come on?
Old Nov 6, 2005 | 08:52 PM
Dave89IROC's Avatar
Re: O2 sensors
not if you run sims
Old Nov 7, 2005 | 03:23 PM
2000GTP's Avatar
Re: O2 sensors
Originally Posted by Dave89IROC
not if you run sims
Thats exactly what I'm doing, running 02 simulators. It is frankly alot easier then having to drill holes in the y-pipe, weld in 02 bungs, and run 02 harness extensions to mount post-cat 02 sensors. Plus, as I mentioned above, I don't feel the cats. I am running may be "efficient" enough so I might get a check engine light anyhow.
Old Nov 7, 2005 | 08:32 PM
TJ Chapman's Avatar
Re: O2 sensors
makes sense. Where did you get your simulators? Which ones are the best for the best price?
Old Nov 7, 2005 | 11:58 PM
2000GTP's Avatar
Re: O2 sensors
The simulators are made by Caspers Electronics and I purchased the pair from www.thunderracing.com for 88.00
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
