o2 sensors
i got my car codes checked today and found out that my o2 sensors are no good. so i ordered new ones and some new headers to go along with them
i love the way i think anyways when they come in i will need alot of desperate help with everything i have never done headers on an lt1 so you will see my name alot up their wish me luck |
forgot to tell you what i bought
mac midlength headers jethot coated with y pipe 1 5/8 primarys im so excited |
the install is fairly straight forward from what i have read.
i know i managed to do my LT install on my LS1 by myself in 10.5 hours. in this situation...it's all about the search button...siince it's probably been asked 100 times oh and i would highly reccomend installing prothan motor mounts while the manifolds are out. they will install VERY easy with nothing in your way, and will prevent the motor from twisting under load...which can cause problems with the headers/ypipe hitting the frame. i have them...and the engine barely moves |
where would you get those motor mounts?
Hey did you guys know that some 96 camaros have flat rear 02's and some have square rear 02's. Anyhow, wassup with the led light on the simmulator? I got a pair and one simm has a red led light it and the other does not. I'm like uhh ok.
So with those bush mounts...do you get alot of idle shake? I bet that feels good. I did my tranny mount and havent done my engine mounts yet. I got more shake and I like it. Some people dont like the shake tho..guess they want the cadilac feel.
Originally posted by teke184 the install is fairly straight forward from what i have read. i know i managed to do my LT install on my LS1 by myself in 10.5 hours. in this situation...it's all about the search button...siince it's probably been asked 100 times oh and i would highly reccomend installing prothan motor mounts while the manifolds are out. they will install VERY easy with nothing in your way, and will prevent the motor from twisting under load...which can cause problems with the headers/ypipe hitting the frame. i have them...and the engine barely moves |
i couldn't tell ANY more shake or vibration
either at idle or while driving i got mine through www.thunderracing.com |
