Need some part numbers + names (Shoebox?)
The entire lower plastic piece with the air dam on it.. hopefully it includes the front wheel wells (its basically completely open).
The plastic piece that goes over the radiator (it has the serp. belt scematic on it) Thanks guys. |
Which car? Different years have different part numbers.
Originally Posted by Green96Z
(Post 5254622)
Air dam (radiator air lower deflector) GM PART # 10229657
LH front wheel house liner GM PART # 10296526 (plastic inner fenders) RH front wheel house liner GM PART # 10296525 RH front end outer deflector GM PART # 10297290 LH front end outer deflector GM PART # 10297291 The outer deflector is at the corner under the bumper. Radiator upper mounting panel GM PART # 10262963 |
You ARE the man shoebox.
