Mirror Replacement
Hey all,
I had some vandles smash out my driver's side door mirror, it's missing pieces and looks pretty bad. How easy is it to change out? I have a 1995 Z28, and I'm a bit worried that maybe my mirror controls may not work properly if I have to replace that. Any suggestions? Thanks |
Very easy. One screw on the plate on the inside of the car, along with 3 nuts for the mirror. Might need to take off door panel to unplug wireing to it unless you can reach it.
[QUOTE=Mirage95;4824329]Hey all,
I had some vandles smash out my driver's side door mirror, it's missing pieces and looks pretty bad. How easy is it to change out? I have a 1995 Z28, and I'm a bit worried that maybe my mirror controls may not work properly if I have to replace that. Any suggestions? There is a company on e-bay that just sells the mirror glass replacement. As long as the housing is not damaged this is a easy & cheap way to go for about $20.00. Wait until you check prices for the whole assembly. |
Mirror..
Hey 96Z..
I undid the screw, and three nut washers, and that allowed the whole mirror and case to pull away (power cable still hooked up). However, I just want to change the glass itself, not the whole thing. The Glass is the only thing broken. Any suggestions? I tried moving the mirror up/down/sideways, to look for some screws or something, but can't see anything... |
