Manual to Auto pedal wiring question
Old Jul 12, 2012 | 01:02 AM
brandonppr's Avatar
I've looked and looked, but could not find anything that shows how these should be.
I have a 96 RS 3.8 M5 and I am putting in a 96 SS LT1 A4 from a donor car. I had all the parts I needed from the donor. I disconnected the manual pedals last year and I just now got around to putting the auto pedals in. I don't remember if there even was this 4 wire blue connector that goes in the switch from the brake pedal. Do manual cars have this plug?
Also which of these wires go to the shifter and what else do I need to do?
OK first, this is a pic of the auto pedals with the wires still plugged in from the auto donor car. It's a blue connector with 2 pink and light blue with black stripe and a green with a white stripe. I can not find this wire anywhere on the manual car. Does it exist or not?
This is the auto pedals installed in the manual car. I plugged in everything that fit. The only one missing is the 4 wire plug. Sorry for the upside down pic. It was right side up when I uploaded it :banghead:
These are the wires that were plugged into the manual by the clutch pedal. There are two wires running down to this and then it has these three connectors. One goes to the white clutch switch and 2 of them I have no idea.
Pic of manual brakes with same harness plugged in from above:
Old Jul 14, 2012 | 09:16 AM
bobdec's Avatar
Re: Manual to Auto pedal wiring question
Don't have a '96 service manual.. On my '94 A4 the brake switch blue/blk wire in conn position A (+12v brake OFF) goes to PCM pin C-14 and also feeds the BTS (Brake Transmission Shift Interrupt) solenoid in the tranny. The the pink wire conn position B +12V ignition on from fuse 9. Could not find what the Green/Wht wire does. Looks like you need that second connector..
jb4xx
Feb 2, 2015 10:00 PM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Jul 4, 2005 05:00 PM
