lt1 noise
while the engine is running it sounds like there is metal brushing on something continuously.. is this related to the hvac unit? had someone check it out.. they think its that but recommended to ask everyone on this forum. thanks
It could be the balancer rubbing against the timing cover.
Tensioner or idler pulley??? A/C compressor clutch??? Power steering pump??? Air pump??? Alternator???
Could be anywhere????? |
thanks for the info.. ill be sure to check out those things tomorrow.. anyone else have advice..?
What did you find? I get that sporadically and it is the AC clutch. Flip on the AC and see if it stops.
