LS1 and LT1 front brake hardlines the same thing?
Old Oct 11, 2004 | 11:29 PM
Dave88LX's Avatar
Mine are gone, need new lines...someone has some out of an '00 SS. Are they the same?
Old Oct 20, 2004 | 10:06 PM
Dave88LX's Avatar
Re: LS1 and LT1 front brake hardlines the same thing?
TTT, need to get this thing running!
Old Oct 20, 2004 | 10:10 PM
Z95m6's Avatar
Are you talking about the Metal line that goes to from master cylinder down to the wheel well? If so they're not exactly the same but should work if you are doing the LS1 brake upgrade if not you may need to bend them to make them work. The LS1 lines end up real close to the LT1 lines and have the same threads as the rubber LT1 and LS1 lines interchange. The only problem might be where they go up to the master cylinder. Actually now that i'm thinking about it they must go from the Master cylinder to the ABS system, then to the wheel. I think they should work.
Old Oct 20, 2004 | 10:36 PM
Dave88LX's Avatar
YEp, the long hardlines...I lost mine during the shuffle. I've got a set out of a 95 V-6, but I need to redo the ends that go up to the MC...might just stick with those, I don't know?
Old Oct 21, 2004 | 11:10 PM
Dave88LX's Avatar
Anyone know for sure?
ddr698
Jan 9, 2015 10:05 AM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
vals95z
Mar 18, 2003 03:45 PM
