Lost Ignition Key
Re: Lost Ignition Key
Lost mine yesterday...posted it in the lounge. I flew home over the weekend and took my car keys off my key ring so my roommate could hold onto them incase it needed to be moved. Went fishing yesterday with my keys in my pocket and lost my ignition key. Found it today in the spot I was sitting. I think with proof of ownership and your I.D. its like $25. All depends on where you go. Its time for me to go get a spare now. Good luck. Nathan
So just to confirm, all you need is proof of ownership and the VIN, and the dealer can sell you a new key with VATS chip (assuming nothing has been changed). Even if the car didn't come from the dealer where you're trying to get a key?
I'm looking at buying a 96 with no keys. Don't want to get screwed later.
If I do get screwed and can't get a new key that works, can I just have a locksmith make a key and get a VATS bypass chip? What's the easiest/cheapest way to bypass VATS? The car is a 96 3.8 5-speed.
thanks!
kevin
thanks!
kevin
I don't know anything, but it'd be way cool if I can. Does LT1 edit work to eliminate VATS on V6s? I reckon it won't do anything else on a V6.... Do I have to buy LT1 edit, or can I borrow it from someone?
I think I'm gonna buy this car....
holy ****...thats expensive for the spare keys u guys are lookin at...i have the resistor pellet a.k.a. "chip" in mine as well and have a local locksmith that made me a copy for $8...he just took my key...hooked a volt-meter up to it to test the resistance of the pellet in it..got a blank with a pellet of the same resistance since there are only 15 different resistance levels, and cut the key to match mine..works perfect with VATS and everything..
thanks!
kevin
thanks!
kevin
I bought it. I'll let y'all know how the key thing goes.
But check the 2 links below on how to bypass VATS with resistors. You may have to try 15 different ones, but they're cheap and it's easy.
http://shbox.com/1/4th_gen_tech2.html#pass_key)
http://shbox.com/1/air_bag_disc_2.jpg
